processing the array elements
This is what I did:
Message 41 of 42
(767 Views)
There's no need for the FOR loop.  Use a Concatinate String on the array and LV will combine all of the elements into a single string.  Where I was running into problems was apparently to scan out the fractional seconds, there needs to be a period.  So I had to add one into the array before converting into a string.
Message 42 of 42
(761 Views)
