random numbers - simulate a dice
Message 12 of 19
(5,065 Views)
hi do you have any idea how to run the dice using LED? as in using 7 LEDs in the form of "H" to simulate the random number..
Message 13 of 19
(5,065 Views)
Hi lynnam,
use a case structure to set those 7 LEDs according to your dice number (it's just 6 cases!). I would suggest using a cluster for the LEDs...
Message 14 of 19
(5,053 Views)
Ok thanks.. I will try.. 😃
Message 15 of 19
(5,033 Views)
I've seen a flurry of "random number - dice posts (two with LED dice, and BTW, one DIE, two or more DICE)."  One wonders if we are doing their homework for them...
Bill
CLD
(Mid-Level minion.)
Message 16 of 19
(5,025 Views)
hello. How you did the block diagram in order for the dice to roll?
Message 17 of 19
(4,867 Views)
ll
Message 18 of 19
(4,864 Views)
Read earlier messages in the thread.
Spoiler
Particularly message 8
Message 19 of 19
(4,848 Views)
