vi missing on new laptop
When I tried to open the vi in a new laptop, it report vi missing as the attached screenshot.
It seems from NIscope, so I installed it and try again, but still the same.
I am using LV2009, any suggestion, thanks.
Message Edited by alex. on 03-24-2010 02:21 AM
Message 1 of 14
(3,567 Views)
Did you install the agilent drivers and support files?
Message 2 of 14
(3,557 Views)
I am not sure, anyway to install them?
Message 3 of 14
(3,551 Views)
Message 4 of 14
(3,543 Views)
I am using USB 5133 with general function, does I still need to install these special driver.
By comparision, the folder below is missing.
C:\Program Files (x86)\National Instruments\LabVIEW 2009\instr.lib\niScope
I manaully copied some folder but seems still some dll missing.
Message 5 of 14
(3,539 Views)
 I suppose the location in right and seems you have got the instr.lib already.
Check this knowledge base
Message 6 of 14
(3,534 Views)
I have read the link, but so far I have never rename or move and driver folder, any suggestion, thank.
Message 7 of 14
(3,523 Views)
And I am using win7, now I reinstall niscope 3.5.1
Message 8 of 14
(3,511 Views)
Accepted by alex.
Instead of trying to copy the files from niScope, I think installing it would be better.
Probably you have the drivers on DVD, or you can download them from the NI website: http://joule.ni.com/nidu/cds/view/p/id/1492/lang/en
Message 9 of 14
(3,510 Views)
ah, I see you've got the same idea Smiley Happy
Since you're installing anyway you might want to use NI-SCOPE 3.6.
Message Edited by dan_u on 03-24-2010 10:18 AM
Message 10 of 14
(3,509 Views)
