ā10-30-2007 05:13 AM
ā10-30-2007 01:36 PM
ā10-31-2007 03:32 AM
ā10-31-2007 10:27 AM
ā11-05-2007 03:51 AM
ā11-05-2007 12:19 PM
ā11-06-2007 01:32 AM
ā11-06-2007 02:33 PM
Hi altella,
Actually I overlooked your initial post about the error message "Could not
load the Automation Support DLL" as that message helps a lot. My
fault...
Anyway, we report that message when we can't load our ActiveX library which is
found in the cviauto.dll located in the c:\windows\system32 directory.
Clearly there has been some installation problem but before we jump into repair
mode, make sure that the cviauto.dll is in that system32 directory and it is
the expected version 7.1.1. If it is, then the problem is some kind of
other incompatibility. In that case, running Dependency Walker on that DLL
should help us locate any dependencies not found.
Let me know what you find!
Best Regards,
ā11-07-2007 02:30 AM
