LabWindows/CVI
Showing results forĀ
Search instead forĀ
Did you mean:Ā
How to integrate Python in CVI
Hi Everyone...
Recently at my work there is a demand to use Python scripts and modules from within CVI.
I have basic CVI 2010 and trying to understand if it is possible to integrate Python scripts and/or modules into CVI code.
What would help is to see some example code maybe?
Or NI documentation  and explaination how to do this?
Thank you,
Alex
ALH
(8,826 Views)
Did you search the forum? There are some discussions about it, see e.g. here or here
(8,822 Views)
Yes, I read these posts but still not clear where to start.
Do I need to install the whole Python environment on the same machine as CVI and then point to different Python include files?
Do I need to have Pythonxx.dll and .lib and .h somewhere and then point there in CVI code?
How do I run Python script fromCVI?
I have too many questios and need some initial guidance to start understanding this...
Thank you!
ALH
(8,814 Views)
Hi Alex H,
To answer your question :
The answer to the first question is yes. These questions are concerned with how to use pithon in c not necessarily CVI. If you search for how to call python code from c you will find a wealth of knowledge to help you create your applications.
Perry S.
Applications Engineer
(8,788 Views)
