Parallel port cvi 9 XP
Hello All,
Has anyone had any luck with direct IO inp and outp access to the parallel port using CVI 9 under XP 32?
I tried it using the parallel.zip example provided by NI and found it did not work.
Thanks!
(3,000 Views)
lunchbreak,
Just out of curiosity, what operating system are you using. The parallel.zip example was written using CVI 5.5 and the parmon.exe attached appears to only work in Windows 95 and 98. Also, I downloaded and ran the example in CVI 2009 and was able to run it fine. I was able to write a value to the port and read the value back correctly. Are you getting some sort of an error when you run this example?
Raj
(2,959 Views)
