Lookout
Is there any way to restore or rebuild a corrupted database?
I'm trying to get information from a database, but it's corrupted and not allowing me to see any availbable traces.  If there any way to restore or rebuild a corrupted database?
Message 1 of 11
(9,646 Views)
Steve,
What version of Lookout/MAX are you using? Are you trying to view the traces through MAX? Are you getting a specific error message or are you just not getting any data. We may be able to rebuild the index file, but some more information will be helpful. Thanks!
Andy F.
Message 2 of 11
(9,635 Views)
I'm using MAX version 3.0.0.3003.  Lookout is version 5.1.  Yeah, I'm trying to view the traces through MAX, but no error comes up.  I just see no information.  There are definitely a lot of files in the database folder on my computer, but I don't know what they are.
Message 3 of 11
(9,632 Views)
Interesting. If you right-click on the database and select properties are you able to retrieve any information? Does it say it has any pages/traces?
Andy F.
Message 4 of 11
(9,619 Views)
Here are a few screen captures of what I'm looking at.  The 3rd capture is of the files making up the database.
Message 5 of 11
(9,604 Views)
It's not sure what's wrong with the database. You should see some traces if it is okay. I notice that there is a red alarm on bottom right corner which should be green if it is fine.
Could you zip all the database files and upload to ftp://ftp.ni.com/incoming?
Let me try to read the database.
Ryan Shi
Message 6 of 11
(9,580 Views)
Message 7 of 11
(9,549 Views)
Accepted by Steve_McLain
The database is fine. See my attached screenshot. I can view the traces.
Try to remove the database in MAX, right click on it and select delete. Just remove it from the tree but leave the data. Then create a new database with the folder in MAX.
Ryan Shi
Message 8 of 11
(9,532 Views)
You know, I was reading it from a drive on our server, but then I extracted the file I sent you onto my local machine and it appears to be working fine.  Thanks for pointing me in the right direction.
Message 9 of 11
(9,518 Views)
Okay, I've got two other databases that I can't get it to work on.  Can you take a look at these?  I tried to extract onto my local machine, but it didn't work this time.
ftp://ftp.ni.com/incoming/Steve%20McLain%20DB2.zip
ftp://ftp.ni.com/incoming/Steve%20McLain%20DB3.zip
Message 10 of 11
(9,502 Views)
