Lookout
LookOut 6.5 hanging
Well, I think I finally figured out the problem and have a partial solution.  The stand alone machine that runs the application is both the server and the client.  In Options>Startup I had the server.l4p and the client.l4p files in the list.  I removed the client file, re-booted the machine and launched Lookout which only started the server file. It only took about two minutes to load.  Then I went to file>open and clicked the client file which launched in a  matter of seconds. This is highly repeatable.  I got this idea from page 3-2 of the 2000 LookOut Operators Manual.  Not sure why this works...
Message 11 of 12
(2,680 Views)
Good catch, we have run into the same problem before as well.
We added a delay on timer to the server process after a successful update from a remote site that loads the client process.
Forshock - Consult.Develop.Solve.
Message 12 of 12
(2,658 Views)
