Lookout
Mailer Object - Specify Port
Ryan,
thank you for the mailer.cbx and mailer file for the port change, however it does not seem to work. I took the file and put it in the lookout directory. I also changed the original mailer.cbx to mailerold. When I boot into lookout I get an error "the original 3116 could not be located in the dynamic link library lkworks.dll" click ok and will not open an existing file with a mail setup. It comes up with "could not load class?" click ok and then gives us an "error running process file". If you setup a new process and try to add a mailer object (object, create, monitoring)the mailer choice is not there.
What are we doing wrong.
Lookout version 6.0.1
Steve
Message 31 of 35
(3,458 Views)
Hello Ryan,
I have a customer using version 4.5 on an older system that was emailing just fine until port 25 was blocked.  Do you have an update that would work for us?
Pete
Message 32 of 35
(3,421 Views)
sorry email address is peter.brini@ (**no spam**) bauerct.com
Message 33 of 35
(3,419 Views)
Hi Ryan,
Having the same issue, using lookout v5.1, need to use port 587.
cheers
Message 34 of 35
(3,269 Views)
Tools that may help you:
Port Mapper:  Maps a local port to a remote port.  For example you could set local port 25 to your servers 587 port.
http://www.analogx.com/contents/download/Network/pmapper/Freeware.htm
Proxy:  Set a local or network proxy that can access other servers and ports
http://www.analogx.com/contents/download/Network/proxy/Freeware.htm
Good luck
Forshock - Consult.Develop.Solve.
Message 35 of 35
(3,262 Views)
