Machine Vision
Cant create a vi from vision assistant.error: labview and imaq missing
I have installed ni labview and vision assistant on my vista-run laptop
Whan i am trying to create a vi from vision assistant,it shows labview and imaq are missing.
Plz try this
Thanks in advance
Message 1 of 9
(4,884 Views)
Which versions LabVIEW/VAS/VDM you have installed?
Message 2 of 9
(4,881 Views)
Message 3 of 9
(4,870 Views)
I'm using labview 8.6 professional version
Message 4 of 9
(4,868 Views)
Try again, please (Message body is empty)
Andrey.
Message 5 of 9
(4,867 Views)
Its also important to know which version of Vision you have installed. For example, if you have installed LabVIEW 8.6, but Vision Development Module 7.x, then it will not work (as far as I remember). So, if you will install LabVIEW 8.6, then Vision Development Module 8.6, and then Vision Acquisition Software 8.6, then it should work.
Also it might not work if you will install at the first VDM, and at the second LabVIEW.
Andrey.
Message 6 of 9
(4,864 Views)
I've installed labview 8.6 first,then vision development module 8.6. Vision assistant was included in this package
Message 7 of 9
(4,844 Views)
I am still not clear how this is possible. Can you post a screen shot of what you get when you click create lv vi? Do you have multiple lv versions and vision tool kit for a previuos version?
Message 8 of 9
(4,834 Views)
Accepted by anil89cs
I have reinstalled labview and other components. Now the problem is solved
Thanks for help
Message 9 of 9
(4,802 Views)
