08-14-2008 10:31 AM
Hi Panmanas,
The reason you have a broken wire is that you have attached two different data types. The data type of your indicator is a Double (float 64) and the data type in the wire is a Dynamic Data Type, which is used to pass live data with time information. You can use the Convert From Dynamic Data Express VI to correct the problem in your code. If you will be developing in LabVIEW in the future at all, you might try checking out the following links:
LabVIEW Learning Center: Getting Started with LabVIEW
LabVIEW Introduction Course - Three Hours
08-14-2008 12:10 PM
08-18-2008 03:35 AM
08-20-2008 09:56 PM
Dear Waleed EI-Badry
Thank you very much for your help and your code.
We shall apply it to our work.
Thank you very much again.
With my best regards,
Panmanas
08-21-2008 01:10 AM
08-22-2008 05:11 AM
We opened your code but suddenly we imedietely saw a broken wire. We attached file for you to see too.
We dont know what was wrong. We use Labview version 8.0 with license.
We tried to solve the problem by using Convert from Dynamic Data Express VI as Wes P recommended. But still the wire is broken.
Please help us again.
Thank you very much.
Panmanas
08-22-2008 05:17 AM - edited 08-22-2008 05:19 AM
Is this conversion required?
08-23-2008 07:54 AM
08-23-2008 09:04 AM
08-25-2008 09:03 PM
Dear Muks and Waleed EI-Badry
Thank you very much indeed for your help. We are are group of lecturer and students who are trying to use LABVIEW in our application.
We have less basic knowledge. That is why we ask you very often.
Thank you very much that you stand for us with kindly help.
When we bought LABVIEW, we asked the dealer to train us for specific course especially for our application but they could not accept it.
I think it is because our application is unique. So they help us to ask from ASEAN NI support and to this NI Discussion forums.
We found that by this way we can get solutions correct and imediately.
I think that all of you work hard. Why dont you come to Thailand and relax for some days.
From November to February, there is no rain.
Panmanas
