08-26-2005 12:25 PM
08-29-2005 04:05 AM
08-29-2005 04:29 AM
Hi Jochen,
You see the camera in the device manager but it is broken (yellow sign). Replacing the camera and cables had no effect.
You can boot the machine 3 or 4 times without problems, then the same problem occurs again. When the machine is running it works without problems, only booting triggers that problem. Only one camera is affected, never both, but it is random which of them not works.
I hope this gives you a hint...
thanks
peter
08-29-2005 07:47 AM
