Machine Vision
NI-MAX GigE camera not discovered
Thanks for the update.  Glad the firewall change fixed the issue!
Clemens | Technical Support Engineer | National Instruments
Message 31 of 32
(883 Views)
I have problems with MAX and my GigE camera .  Is not possible to see camera into "devices and Interfaces" tree. The Camera is a Basler ace and works well with vendor's SW (Pylon5). Also Laptop's embedded camera is not shown into MAX tree . I already uninstalled all NI Drivers and Softwares (using also MSIBlast procedure as recommended me by an NI Application Eng) and then installed NI SW and drivers . I read a lot of posts but i wasn't able to solve my problems.
My Config is : Labview2103, Vision 2013 , IMaqdx 4.3.5 , IMAQ I/O 2.9 , IMAQ 4.9 . I have a HP ProBook Laptop .
In attached what I see with MAX .
Message 32 of 32
(853 Views)
