Machine Vision
NI Vision Builder: calculating orientation of the component relative to the first image in degrees
where is the images?
Message 11 of 14
(1,969 Views)
sorry man but I could not find any image or attachment ?!!
could you send them into my email?!
Message 12 of 14
(1,969 Views)
Accepted by stealthengineer
I see your image it is easy to find  orientation
you have three ROI that could help you
one is hole that exist in Hinge and two others are two end of your device
use geometry matching and make two template  for multitemplate matching one for hole and next for one of the end of your device arms
now problem is solved  you have a line from two position that your Learn and find in your image after that you can use some mathematics equation to find line orientation in any other image of your device  best one is to calculate tangent for that lines
Message 13 of 14
(1,956 Views)
I figured an alternative way where  you can insert a data log feature which enable you to find the match angle pattern and tells you the difference between the orientation of the image to the initial image entered. Thank you for your advice!
Message 14 of 14
(1,940 Views)
