I've built several vision aquisition and analysis apps with VB and CWIMAQ. Now, I'd like to do a pattern matching application, however, I can't seem to get the same functionality and speed with the VB component as I can using VisionBuilder! Attached is a grayscale image of a microtiterplate, and a "pattern" of a well or "hole". Using pattern matching in visionbuilder there are about 96 matches, which is perfect, dang near a match for every well. However, if I try to reverse engineer the VB "FeatureFind" example and use the attached picture and pattern, the "Correlation" takes a VERY long time (14 seconds for VB featurefind app, instant for VisionBuilder), and it doesn't even match!
Even though I can't use
visionbuilder in my final application, it works almost perfectly when I use the attached image and pattern while setting the minimum score to 50. I wish I could implement the same thing in VB, that is, if NatInst could tell me the CWIMAQ components function calls used to implement it :-0)
Any Ideas? Thanks
