Machine Vision
What's the differences between "IMAQ Find Circular Edge.vi" and "IMAQ Detect Circles.vi"
Hello,All
 Both VI "IMAQ Find Circular Edge.vi" and "IMAQ Detect Circles.vi" can detect circular, both can get the coordinate of circular's center and the radius,but I 'm not clear about the differences,the respective advantages and the disadvantages.In which case I use "IMAQ Detect Circles.vi" is better?and vice versa.Thanks!
Striving is without limit!
(5,505 Views)
Does anyone clear?I am looking forward to hearing from you soon.Thanks!
(5,459 Views)
Accepted by leq_82
Below are my inferences:
IMAQ Find Circular Edge.vi and IMAQ Detect Circles.vi can be used to detect circle. The main difference between them is how they get the edge points and do a circle fit:
IMAQ Find Circular Edge.vi: Internally uses Spoke which uses annular ROI and along the search lines specified identifies edge points and then does Circle fit on the points obtained.(Ref: http://zone.ni.com/reference/en-XX/help/370281AD-01/nivisionconcepts/edge_detection_concepts/)
IMAQ Detect Circles.vi: Uses Curve extraction and contour analysis algorithm to identify the curves and detect the circle (Ref: http://zone.ni.com/reference/en-XX/help/370281AD-01/nivisionconcepts/contour_analysis_concepts/)
-Apart from above one more difference is type of images on which algorithm can be used: IMAQ Detect Circles.vi works only on U8 images whereas IMAQ Find Circular Edge.vi works on below types (Ref: http://zone.ni.com/reference/en-XX/help/370281U-01/imaqvision/imaq_find_circular_edge_3/)
uday
(5,437 Views)
uday,Thanks!
(5,428 Views)
