Machine Vision
how the carmera open via imaqdx use so long time up to 71S?
Basler acA2500-14gc  camera       how the carmera open via imaqdx use so long time up to 71S?
is there some setting in camera need to be modify?
(3,843 Views)
Have you tried updating IMAQdx? New versions contain updated versions of the standard GenApi/GenICam component that address some performance issues loading the camera's XML file. Unfortunately the Basler cameras have some pretty complex XML files and so when they are used with older GenApi versions they are quite slow to load.
Eric
(3,835 Views)
my imaqdx is 3.4 now
(3,828 Views)
Accepted by Hugo_ye
3.4 is extremely old. You probably want to update the 4.0 which is part of the latest Vision Acquisition package:
http://joule.ni.com/nidu/cds/view/p/id/2975/lang/en
Eric
(3,822 Views)
Thank you very much, BlueCheese !
the issue is closed, ths!
(3,814 Views)
