Measure
How to measure magnetic fields?
my new task is to measure a magnetic field up to 2-3 Tesla and i wanted to ask whether someone can advice hardware (Hall Probe+DAQ hardware or stand alone Teslameter)?
best regards
Norbert
Message 1 of 10
(9,536 Views)
Hi Norbert,
we have a lot of devices for measuring voltage. Which one to choose depends on which platform you prefer (PCI, PXI, USB)
and which accuracy you need. I assume you also need an external voltage supply for the sensor?
So the hardware needs to provide this too.
You will find a hardware overview here: https://www.ni.com/en/shop/data-acquisition.html
Regards
DianaS
Message 2 of 10
(9,518 Views)
Hi Diana,
i know the NI Meas. hardware, but it seems to be really difficult to find a probe with complete application notes for this task.
As platform USB and PCI would fit perfect.
best regards
Norbert
Message 3 of 10
(9,515 Views)
Hi Norbert,
what does the output of your sensor look like? Is it TTL? Which range is the signal measured in volts?
Regards
DianaS
Message 4 of 10
(9,512 Views)
oh, there is a misunderstanding,
i have the task to measure and control the field, but at the moment i only have a big FuG Power supply and a hugh magnet. At the moment i am searching a measurement system to do this, especially a probe. You can buy a lot of probes, but the belong always to a special measurement unit and there is no documentation or application notes.
It is also possible to buy these stand-alone measurement system with probe and a GPIB interface, but these solution is really expensive.
best regards.
Message 5 of 10
(9,510 Views)
Ah I understand. But National Instruments only provides measurement hardware but not probes.
So when you have a concrete probe we can advise a hardware.
Regards
DianaS
Message 6 of 10
(9,508 Views)
i know this fact, but i thought this is a user forum and someone else have already solved such a problem and could tell me a solution.
best regards
Message 7 of 10
(9,506 Views)
ok i have found a sensor
http://www.cunz.de/documents/FWB-GH-series-en.pdf
the GH-600, which NI hardware do i need, when i want to exclude an additional current source?
best regards
Message 8 of 10
(9,503 Views)
Hi Norbert,
maybe this board would fit: https://www.ni.com/en-us/support/model.pci-6281.html
It can output 5mA and measure voltage with high precision.
Regards
DianaS
Message 9 of 10
(9,482 Views)
Hello
Take a look of www.senis.ch
There is possible to find a 3D magnetic field probe integrated with USB DAQ
Sasa
Message 10 of 10
(8,993 Views)
