PCI-6111 not responding to reference triggers
Using the .NET (C#) DAQmx dirvers I am not getting a reference trigger when using a PCI-6111. I get the triggers fine with a PCI-6115 and PC-MIO-16. I was under the impression that the API was not device specific, so I am a bit surprised by the behaviour.
I previously ran into an issue with a few particular 6111s, and had to modify the code to get around that. I am assuming that the previous problem has been solved. Here is what I am doing:
foreach (int channelIndex in m_ActiveChannelList)
string channelName = string.Empty;
// Set this to -1 to let the NI driver decide which terminal configuration to use
int useDefaultTerminalConfig = -1;
// Get the name of the current channel
channelName = BASE_CHANNEL_NAME + channelIndex;
// Create the channel
m_DAQmxTask.AIChannels.CreateVoltageChannel(m_Device.AIPhysicalChannels[channelIndex], channelName, (
AITerminalConfiguration)useDefaultTerminalConfig,
-10.0, 10.0,
AIVoltageUnits.Volts);
foreach (AIChannel curChannel in m_DAQmxTask.AIChannels)
curChannel.DataTransferMechanism =
AIDataTransferMechanism.Interrupts;
// Setup the sample clock
m_DAQmxTask.Timing.ConfigureSampleClock(
string.Empty, m_ClockFrequency, SampleClockActiveEdge.Rising,
SampleQuantityMode.FiniteSamples, m_NScans);
// Setup the reference trigger
m_DAQmxTask.Triggers.ReferenceTrigger.ConfigureDigitalEdgeTrigger(
"PFI1", DigitalEdgeReferenceTriggerEdge.Rising, m_PreTriggersScans);
// Set the time out
m_DAQmxTask.Stream.Timeout = (m_Timeout * 1000) - 500;
(3,984 Views)
Hello All,
Tyzack has contacted National Instruments directly for Technical Support. I will post a resolution to this issue when we determine one, but I encourage users with any insight to post any ideas they may have.
Matt Anderson
Hardware Services Marketing Manager
(3,947 Views)
Accepted by Tyzack
This appears to have been related to a faulty board.
(3,845 Views)
