PCI-6111 not responding to reference triggers
Using the .NET (C#) DAQmx dirvers I am not getting a reference trigger when using a PCI-6111. I get the triggers fine with a PCI-6115 and PC-MIO-16. I was under the impression that the API was not device specific, so I am a bit surprised by the behaviour.
I previously ran into an issue with a few particular 6111s, and had to modify the code to get around that. I am assuming that the previous problem has been solved. Here is what I am doing:
foreach (int channelIndex in m_ActiveChannelList)
string channelName = string.Empty;
// Set this to -1 to let the NI driver decide which terminal configuration to use
int useDefaultTerminalConfig = -1;
// Get the name of the current channel
channelName = BASE_CHANNEL_NAME + channelIndex;
// Create the channel
m_DAQmxTask.AIChannels.CreateVoltageChannel(m_Device.AIPhysicalChannels[channelIndex], channelName, (
AITerminalConfiguration)useDefaultTerminalConfig,
-10.0, 10.0,
AIVoltageUnits.Volts);
foreach (AIChannel curChannel in m_DAQmxTask.AIChannels)
curChannel.DataTransferMechanism =
AIDataTransferMechanism.Interrupts;
// Setup the sample clock
m_DAQmxTask.Timing.ConfigureSampleClock(
string.Empty, m_ClockFrequency, SampleClockActiveEdge.Rising,
SampleQuantityMode.FiniteSamples, m_NScans);
// Setup the reference trigger
m_DAQmxTask.Triggers.ReferenceTrigger.ConfigureDigitalEdgeTrigger(
"PFI1", DigitalEdgeReferenceTriggerEdge.Rising, m_PreTriggersScans);
// Set the time out
m_DAQmxTask.Stream.Timeout = (m_Timeout * 1000) - 500;
(3,975 Views)
Hello All,
Tyzack has contacted National Instruments directly for Technical Support. I will post a resolution to this issue when we determine one, but I encourage users with any insight to post any ideas they may have.
Matt Anderson
Hardware Services Marketing Manager
(3,938 Views)
Accepted by topic author Tyzack
This appears to have been related to a faulty board.
(3,836 Views)
