Measurement Studio for VC++
determine usb port
I have a problem with this configuration:
How can I determine which USB 6210 device is on USB 1 together with the USB to RS485 converter? I communicate with the converter via CreateFile().
thanx!!
(7,083 Views)
there is a way that i think it will work.. when you put usb in that port force labiew to send a little text file or something like this in that port then always send a file to the device that has this text .
don not connect both of them at once.
(7,048 Views)
thank you. i forgot to write that i do not use labview but c++.
(7,045 Views)
Accepted by mael15
i solved this problem. just in case someone needs the solution: i was able to recursively loop through all usb hubs/devices using the winApi by tailoring this source code:
http://mtpretag.googlecode.com/svn-history/r3/trunk/c-source/jusbpmp_native_source/displayusb.c
(7,015 Views)
😉 good job .
(7,007 Views)
