Motion Control and Motor Drives
Dynamixel motors control using Labview SDK
Hi everyone,
I need to control 3 Dynamixel MX-64AR using Labview SDK. I already donwloaded the Dynamixel SDK file and found its Labview files. Then I did a reasearch on the net to follow all the steps in order to add the Dynamixel  Library in Labview.
However, In the Labview folder of Dynamixel SDK, I find only the .dll file, but not the header file .h, and in order to add this library in Labview, we need both of them.
So, if anyone knows the complete steps that I should follow in order to control Dynamixel motors using Labview, help me please
that picture shows what the Labview folder of Dynamixel SDK contains .Dynamixel Labview.png
(3,610 Views)
Accepted by Crypps
Dear Crypps,
Where did you download the Dynamixel SDK from? I found this site:
Dynamixel SDK for Windows
Which according to their FAQ page, only DXL communication 1.0 works with LabVIEW.
Also, I am assuming that you are going through the steps in this article: LabVIEW: Dynamixel SDK, and are getting stuck at the point where you need to find the header file. When I downloaded the file from the first link, it looked different from your picture, and it also had a header file.
Alyssa H.
(3,570 Views)
Thank you for your help Alyssa.h, I  had the wrong DynamixelSDK folder, that's why I didn't found the header filer (.h)
Now I succeded to add the Dynamixel library in Labview.
Next step .... controlling the motors    Smiley Wink
(3,563 Views)
