Motion Control and Motor Drives
User-defined points in contouring
I'm using PCI-7344 & UMI 7764 to control dc motor on servo mode,
but i have a question,
when i define contouring points that value was smaller than 1000,
the program was worked,
but when the value was greater than 1001, there was an error.
thanks.
由 ycw7 在 02-09-2006 12:22 AM 上編輯的訊息
由 ycw7 在 02-09-2006 12:24 AM 上編輯的訊息
●LV Version:LabVIEW7.1
●OS:WindowsXP(SP1)
●Hardware:PCI-7344, PCI-6602, PCMCIA 6024E
(3,136 Views)
Hey ycw7,
I would recommend that you increase the timeout value on the Wait For Move Complete.flx. If you do not have a value wired into this, then wire in something greater than the default, which is 10000 ms. Also, what does the Find Empty Buffer.VI do? You did not attach this VI so it did not open up with the rest of the program. Have you tried to just remove the Find Empty Buffer.VI and does it work? Have you tried increasing the requested interval time? Try increasing the timeout value on the Wait For Move Complete VI and let us know if this helps. Let me know if you have any further questions or concerns. Thanks, and have a great day.
DJ L.
(3,099 Views)
