05-09-2002 01:08 PM
05-10-2002
07:13 PM
- last edited on
06-27-2026
08:01 PM
by
Content Cleaner
You might want to take a look at the following knowledgebases :
Link1 [broken link removed]
It is really difficult to say when it will be supported.
Sastry V
05-11-2002 04:19 AM
05-13-2002 11:18 AM
05-13-2002
11:56 AM
- last edited on
06-27-2026
08:01 PM
by
Content Cleaner
Hi Mark,
The best way to get to the document referred by Sastry is to search for KnowledgeBase ID 2KA6M0YJ. You can search for it by using the KnowledgeBase link in Option 3 at http://www.ni.com/support.
If it doesn't work for you, you can try this direct link:
Link2 [broken link removed; article no longer available]
Best Regards,
Wilbur Shen
Web Support and Operations
05-13-2002 12:16 PM
05-13-2002 12:09 PM
05-14-2002 10:26 AM
12-17-2012 08:22 AM
Hi Mark,
I'm a test engineer trying to use an NI DIO 96 card in a 64 bit machine however the issue I am having is in the driver. I haven't been able to install the NIDAQ32.dll and was hoping that you might be able to lead me to where I could locate a 64 bit driver suitable for use with LabVIEW 2009. I see in the forum that you were having issues with the asssociated 32 or 64 bit slots and was hopin that you might have some ideas on the driver. Any help is appreciated.
Regards
Rich Mc
12-17-2012 09:43 AM
You've hijacked a very old and unrelated thread.
The 64 bit driver for NI DAQ cards is DAQmx. Simply click on the support tab at the top of the page.
