07-29-2008 03:34 AM
07-30-2008 11:26 AM
Hi Serkan,
There are many useful shipped examples with LabVIEW. If I got you right, there's one example, " Acq&Graph Voltage-Ext Clk-Analog Ref ", that does exactly what you are talking about except that the sample clock in the example is external. You ca neasily set it to external by simply deleting the source terminal on the " DAQmx Timing " VI.
You can find this example in LabVIEW by going to Help >> Find Examples >> Hardware Input and Output >> NI-DAQmx >> Analog Measurement >> Voltage .
Faris
