Multifunction DAQ
Error allocating memory for DMA (memPageLockError -10447) for NI6115 under Windows XP
I encounter a problem when I try to allocate DMA memory above 1 Mbyte for my NI6115 card under Windows XP. The error message is memPageLockError (-10447). This seems to depend on the state of the computer. We have 256 Mbyte memory installed and I want to use 10-20 Mbytes for data acquisition. Practically the same program worked previously for a 6110 card on Windows NT. I suspect this has something to do with XP memory usage, what should I change? I attach my C++ routines, NI_measure does the memory allocation.
(2,743 Views)
No sure which version of NI-DAQ you're using... if it's NI-DAQ 6.9.3, there is a patch 6.9.3f4 which deals with a memory issue found in the 6115/6120 boards.
(2,743 Views)
No answer, sorry.
I run into a the same error and do not know what is going wrong.Do you find a solution?
Stephan
(2,743 Views)
