03-26-2008 10:15 PM
03-27-2008
04:08 PM
- last edited on
04-29-2024
09:04 AM
by
Content Cleaner
Hello Areg
Thank you for using our discussion forums.
The maximum input sampling rate for the PCI-6259 is 1.25MHz. So it looks like this error is occurring because you are requesting a sampling rate that exceeds the capabilities of the card. For more detailed specifications on this DAQ device, please see the following link.
If you need a card that can sample at a higher rate, please check our hardware configuration page linked here, and select the needed requirements to limit the results.
Chris_K
