11-27-2008 02:03 AM
I cannot generate a PWM signal with my PXI-6232. I'm using the CO Pulse Freq tool. I tried to do the same in MAX and it doesnt work, so I guess my card cannot generate PWM signals or is damaged.
I can generate this PWM signal with a PXI-6229, the problem is that the output is always 0-5 volts, and I need 0-10 volts, if not my application is not able to read this PWM signal. Can I change the output of this card to 10 volts?
Can you give me some suggestions to generate a PWM signal with an output 0-10 volts?
Thanks for any help.
11-27-2008 10:04 AM
