‎11-12-2009 09:29 AM
Hi.
I have a ni4472 in my rack.
To communicate with it I open /Dev1/ai0
If I replace the board, and I make a nilsdev I can see that my board is now in Dev2 and that Dev1 is not used.
As I don't know what the customers do with the spare boards, I might be in this case.
I could enumerate the device and use dev1 or dev2 or devx depending on the cases, but I would prefer to have always Dev1
I guess that the config is stored in a file somewhere.
Do you know where?
Do you know a clean way to have always dev1 ? (remove a file, patch a file?)
‎11-12-2009 02:26 PM
DAQmx configuration information is actually stored in a database - not a file.
That being said, the best way to ensure that a device has a specific name is through the import/export feature (typically used in deployment scenarios).
If you are not familiar with this feature, here's an introduction:
1. From MAX, you can select File>>Export to export your configuration for any or all devices/tasks/channels (I'd recommend exporting to ini or txt file).
2. On a system, you can import that configuration by selecting File>>Import, or you can programmatically import with a MAX Copy Configuration function.
As well, please note that I would not recommend using "Dev1" for your reserved name because that is a default name. If you name it something like, "TemperatureDev", for example, you will never have a conflict. (Even with importing a configuration, it will not automatically rename another device using your name).
‎11-12-2009 04:47 PM
Joe Friedchicken
NI Configuration Based Software Get with your fellow OS users
[ Linux ] [ macOS ]Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
‎11-13-2009 02:08 AM
Hi
Ok, I didn't use nidaqmxconfig yet.
However, as the serial num of the board might change at any reboot, I probably need to have a script that will make an import / patch the file / export...
Chris
