Installed NI-DAQmx 8.3. No DAQmx in MAX. NewHardware saw USB-6008.
I did both steps, when you asked me to do so. Did not work. See details above, when I replied to your message.
Message 21 of 23
(866 Views)
Actually I would like to ask you to solve this problem from a different approach, since I have this issue for weeks and still did not figure out the solution. I tried to uninstall/reinstall the whole NI package several times, but seems to happen that some files does not get uninstalled which might cause this problem. So my question is the following: How can I completely erase the whole NI package from my computer (don't say format c:) in order to I can start a clean reinstall? It was working previously, how I told you in the previous posts, but I crashed to computer somehow, several times, then probably I did deleted some stuff which corrupted the NI system afterwards. I think I right clicked on my devive  in MAX (in that era when it was recognized by MAX) and hit delete.
Thank you.
Message 22 of 23
(865 Views)
Any corruption to the installed files should be fixed by just doing a repair, and a complete reinstall should definitely fix any corrupted files.
Message 23 of 23
(815 Views)
