Multifunction DAQ
Max Sampling rate of NI 9411 for couter input
Can someone help me with the maximum sampling rate of NI 9411 module? Which I'm not able to locate in the datasheet.
My application is to measure the RPM of the motor using an encoder - I want to measure the frequency and convert the same to RPM
Regards
Naveen
(1,885 Views)
Accepted by nforce_212
It sounds like you might have a misconception about counter tasks.  It isn't necessary to have a very high sample rate when measuring frequency.  In fact, high sample rates lead to larger quantization error effects.
In any event, your 9411 module is mainly a pass-through interface for your digital signals.  The cDAQ chassis contains the clocks and timing engines used for sampling.  Look up manuals and docs for your particular chassis to see what methods it supports for frequency measurement and get a better understanding of how they work.
   FWIW, when I was doing similar measurements, I most typically used the method called "Low Frequency with 1 Counter".
-Kevin P
(1,859 Views)
Hi Kevin,
Thank you for your suggestion, I did go through the cDAQ-9189 manual to understand different frequency measurement options.
Regards
Naveeb
(1,774 Views)
