NI PCI 6115 AO disabled
Message 11 of 17
(1,245 Views)
Message 12 of 17
(1,245 Views)
Don't understand the point of posting those overly large files. They don't show the self-test tab and you have not answered whether you ran that or not.
Message 13 of 17
(1,238 Views)
I did run it and it passed.
Message 14 of 17
(1,234 Views)
Then you should probably contact NI either via phone or the Support link above. It sounds like you might have a damaged board.
Message 15 of 17
(1,231 Views)
I agree with Denise.  You should call up NI and see what they say.  However, I did look at the screen shoots, and I saw that you are trying to check your AO1 with your AI1.  Play with the setting a little.  Try a continuous mode and constant voltage instead.
Kudos and Accepted as Solution are welcome!
Message 16 of 17
(1,222 Views)
Hi, have you solved the problem?
Message 17 of 17
(974 Views)
