Problem with CDAQ - 9185
Struggling to troubleshoot this error after hooking up my CDAQ 9185 and thermocouple module (NI 9212). When i go to run Test Panels in NI MAX, this is the error I receive. Any help is greatly appreciated.
Error - 209836
The devices in your task cannot be synchronized. This may be because there are no available synchronization mechanisms between the devices.
Message 1 of 10
(5,315 Views)
Hi ARTongue,
Does this occur with both 9212 modules in your chassis or just one?
Jen P.
Applications Engineering
Message 2 of 10
(5,276 Views)
It occurs with both 9212 modules. It appears to be some sort of issues with windows 10 and the hardware functions as expected when ran on a windows 8 PC.
Message 3 of 10
(5,269 Views)
Are all driver versions the same on both computers?
Jen P.
Message 4 of 10
(5,251 Views)
Ni-DAQ mx 17.6 is installed on both computers
Message 5 of 10
(5,249 Views)
Do you have any other cDAQ chassis available that you could try putting these modules into? I tried simulating your devices in MAX and ran into no errors. I am currently using DAQmx 17.1.
Jen P.
Message 6 of 10
(5,236 Views)
I do not. The error is something to do with the software. Everything works fine on our Windows 8 PC and the error only occurs on my Windows 10 PC.
Message 7 of 10
(5,234 Views)
Do you happen to know what version of Windows 10, for documentation purposes? Was it working before and thenyou updated Windows 10 and experienced this error?
Jen P.
Message 8 of 10
(5,232 Views)
Edition: Windows 10 Pro
Version: 1709
OS Build: 16299.309
The hardware was received on Monday and it has not worked on my Windows 10 PC right out of the box. No Windows 10 update was performed.
Message 9 of 10
(5,230 Views)
How did you resolve this?
Message 10 of 10
(4,284 Views)
