Multifunction DAQ
Python nidaqmx does not detect all the devices connected to my system
Hello all,
I'm trying to detect all the NI devices connected to my system to retrieve their names and which PXI and slot it is in. I can see it in NI MAX, my SMU is NI PXIe-4140 (see below).
When I run my python code, the library can only detect my switch matrix (NI PXI-2532) (see below).
Is there something I'm doing wrong? if not, is there another library I can use for my purpose?
(3,799 Views)
The PXIe-4140 uses the NI-DCPower API, not NI-DAQmx. You need to install that driver via NI Package Manager and the Python library from pypi (see https://pypi.org/project/nidcpower/)
Note that although the PXI-2532 is recognized by NI-DAQmx, support for switches in that API is deprecated (and I believe nonexistent in Python) You should use NI-SWITCH (and the Python library from https://pypi.org/project/niswitch/).
Tobias
Principal Software Engineer
Driver Software
(3,794 Views)
Hello Tobias,
Thanks for replying, the reason im using nidaqmx is so that I can get a resource name, as to use NIDCPower to initialise a NIDCPower session a resource name is required; see below
Is there any other way to find the resource name (PXI and slot numbers) with python?
(3,789 Views)
Accepted by Enuker
You can use NI System Config API (nisyscfg · PyPI)
Use dcpowerscx (Valid Experts for the System Configuration API Functions) as the resource.expert_name
https://tmesystems.net/
(3,772 Views)
This is exactly what I'm looking for. Thank you.
(3,761 Views)
