My application Builds fine in LV 7.0, however in LV 8.2 using the Project folder, I receive the following :
Polymorphic VIs cannot be used as Startup/Exported or Dynamic VIs for applications or shared libraries.
C:\NEM DS18S20 TEST-8.20\NEM0775B\NEM0775B.llb\VISA Configure Serial Port
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
Error 1035 occurred at ABAPI Dist Check if PolyVI.vi -> ABAPI Load All Libraries And VIs.vi -> ABAPI Dist Build LLB Image.vi -> ABAPI Copy Files and Apply Settings.vi -> EBEP_Invoke_Build_Engine.vi -> EBUIP_Build_Invoke.vi -> EBUIP_Build_Rule_Editor.vi -> EBUIP_Item_OnDoProperties.vi -> EBUIP_Item_OnDoProperties.vi.ProxyCaller
Possible reason(s):
LabVIEW: Operation is invalid for this type of VI.
I am using, Polymorphic VI = VISA Configure Serial Port to configure my serial port and then count bytes received for certain serial Port CmDs.
I am only using the Serial Port (Instr) of the Polymorphic VI. What is the easiest way to BUILD a application that will work???? I've used this method back to 4.1. This new BUILD/PROJECT METHOD is not good.
Please Help
Brian Campbell
