Multifunction DAQ
nidaq channels not visible to opc client
I have a NiDAQ 9188 connected to a PC via ethernet. All of the modules are visible in MAX and check out OK but if I try to connect using OPC, I can only see one item "ServerPollingRate". Is there something I need to do to get the NI OPC server to pubish the channels?
This is my first time with the 9188, I have used compact fieldpoint expansion chassis many times before without any trouble.
(3,221 Views)
Accepted by monkeyfinger
Hey,
Are you running an NI OPC server on the PC? What are you trying to read with/ publish to?
It would be useful to have a system diagram or description, and what you have done so far in terms of setting up.
Here is a pretty good overview of how to set up OPC with DAQmx, it might have the answers you are looking for.
http://www.ni.com/white-paper/3742/en
Ian S
Applications Engineer CLA
National Instruments UK&Ireland
(3,202 Views)
Ian,
Thanks for the link to the overview document. I wasn't aware that I needed to define shared variables for the channels. Now that I have done that I can read the channels via OPC.
Thanks for your help.
Tony
(3,198 Views)
No problem, glad I we could resolve the issue
Ian S
(3,196 Views)
