Showing results forĀ
Search instead forĀ
Did you mean:Ā
program ni usb in linux
I am trying to program ni usb 6008 in ubuntu, any idea about how to code in c++ for this device in ubuntu
Message 1 of 8
(4,275 Views)
To use a USB-6008 with linux you will need to use DAQmx Base.  This will also install examples in /usr/local/natinst/nidaqmxbase/examples.
Doug
Doug Farrell
Solutions Marketing - Automotive
National Instruments Automotive Solutions
Message 2 of 8
(4,258 Views)
I tried running the examples on ubuntu, but the libraries are not linked, also am  not able to detect the device
Message 3 of 8
(4,224 Views)
Ubuntu is not an officially supported platform of National Instruments, so that could be the issue that we are running into.
Supported Linux Platforms
Doug Farrell
Message 4 of 8
(4,209 Views)
It is now supported 2025
running on linux mint.  Im trying to install a basic usb 6008 trying to find the drivers
Message 5 of 8
(1,032 Views)
NI-DAQmx now supports Linux Desktop but does not support Linux Mint and USB-6008.
Reference: NI Hardware and Software Operating System Compatibility
https://tmesystems.net/
Message 6 of 8
(1,025 Views)
Linux mint is built  Ubuntu. Mint built on this and customize the interface.
we are trying to install https://www.ni.com/en/support/downloads/drivers/download.ni-daqmx-base.html
nidaqmx base hopefully it works. I’ll let you know.
Message 7 of 8
(1,016 Views)
NI-DAQmx Base is unsupported since a long time. I think they stopped doing anything for NI-DAQmx Base around 2016 when they focused on getting NI-DAQmx for Linux running. It's not likely that you can get NI-DAQmx Base working on a recent Linux distribution without some serious work.
Rolf Kalbermatter  My Blog
Message 8 of 8
(974 Views)
