10-12-2009 10:19 AM
We need to collect 8 channels of AI input at about 32KS/s but they need to be accurately synchronized. We are thinking to use 2 CDAQ-9215 modules mounted on a CDAQ-9174 chassis. Can this system do the job? And what type of timing and clock configuration should I use to improve synchronization accuracy.
Thanks.
Solved! Go to Solution.
		10-13-2009
		10:40 AM
 - last edited on
		03-14-2025
		01:18 PM
 by
			Content Cleaner
The CompactDAQ chassis is multiplexed so that isn't really a good solution for you. Our new X series 636x cards can do simultaneous sampling but if you only need to go 32ks/s I would recommend this as the lowest cost.
https://www.ni.com/en-us/support/model.pci-6143.html
10-13-2009 01:03 PM
I apologize I did not realize the 9215 was a simultaneous module. Instead of the S series card you should be good to go with a 9174 and 2 9215 modules. If you use the same DAQmx task to run the acquisition on all 8 channels they will all share the same timing engine and sample simultaneously.
10-13-2009 01:32 PM
