synchronize 2 cDAQ-9215 modules on cDAQ-9174
 We need to collect 8 channels of AI input at about 32KS/s but they need to be accurately synchronized. We are thinking to use 2 CDAQ-9215 modules mounted on a CDAQ-9174 chassis.  Can this system do the job? And what type of timing and clock configuration should I use to improve synchronization accuracy.
Thanks.
(3,700 Views)
The CompactDAQ chassis is multiplexed so that isn't really a good solution for you.  Our new X series 636x cards can do simultaneous sampling but if you only need to go 32ks/s I would recommend this as the lowest cost.
https://www.ni.com/en-us/support/model.pci-6143.html
Doug Farrell
Solutions Marketing - Automotive
National Instruments Automotive Solutions
(3,680 Views)
Accepted by gangmei
I apologize I did not realize the 9215 was a simultaneous module.  Instead of the S series card you should be good to go with a 9174 and 2 9215 modules. If you use the same DAQmx task to run the acquisition on all 8 channels they will all share the same timing engine and sample simultaneously.
Doug Farrell
(3,652 Views)
Thanks a lot!
(3,643 Views)
