Multisim and Ultiboard
Making an "ring" type of copper area in Ultiboard
I am trying to design a circular PCB with a 3 node "target" pattern of copper (a center dot with two copper rings of progressively larger diameters with space between nodes). Can this be done with a combination of keepout areas and circular mass areas?
(3,293 Views)
Accepted by Todc.18
You can use the fill style of a circular copper area to create your ring shape.
1) Create a circular copper area.
2) Enter its properties (double click or right click -> properties) and change the fill style to empty in the Copper Area tab.
3) Use the Width in the general tab to determine your ring width.
(3,265 Views)
