Multisim and Ultiboard
Traces inexplicably change from angular to elliptical during hand routing in Ultiboard
I have been running into an issue over the past couple of months where I'll be routing angular (predictable) traces for a few hours and suddenly the traces I'm routing become elliptical (arcs in place of angles and straight lines). I want to convert them back to angular, but I can't seem to find a way to do it. There is nothing I can find in the manual about this. Can someone enlighten me? Am I hitting a shortcut key accidentally or something? Thanks muchly. Todc
(3,970 Views)
Todc.18,
The <space> key toggles the various line drawing modes but I think arcs are not part of the manual 'line' mode (you have to specifically draw an arc, etc...)
The shortcuts for the various line draw modes are shown from the Place menu... To check or alter you can check and setup special shortcuts by customizing the menu.
Pat
(3,965 Views)
Accepted by Todc.18
Thanks, I'll try hitting the space key next time.
(3,962 Views)
