Multisim and Ultiboard
circuit not working
hello
i am new in multisim and i am going through a tutorial on how to use multisim. I have created a circuit including two lamps and when running the simulation the lamps are supposed to light depending on the switch being switched. I can't get it to work. Could anyone please look at my design and tell what's wrong?
(3,423 Views)
Accepted by fisqen
Use the current and voltage probes to find that all the voltage is across the 10K resistors. Only 1.2mA of current is not even enough for LED's. Why do you need the resistors? Take the lamp directly to ground. The lamp will light and your power probe will show 10 watts.
Jim
(3,394 Views)
