Multisim and Ultiboard
delete component without deleting wires
In the schematic editor, how do I select a component and delete it without deleting all of the wires attached to it?  I don't want to use the "replace component" menu option because I want to do something else.
I'm sure I'm just missing something simple...
Dave
(9,492 Views)
Place a junction node on the wire near the pins you want the wires to to stay.  Delete the component, the junction points will hold the wires in place to make the needed changes you want after that.
Signature: Looking for a footprint, component, model? Might be here > http://ni.kittmaster.com
(9,481 Views)
Good tip, thanks.  I was hoping for a modifier, like ctrl or shift with the delete key.
(9,458 Views)
Hi all,
This might help too:
  1. Select the component you want to delete
  2. Hold down the spacebar
  3. Drag the component to a blank part of your schematic. Note how your component was moved while preserving all connecting wires.
  4. Delete the component
Yi
Software Developer
National Instruments - Electronics Workbench Group
(9,450 Views)
Accepted by dbadger
That's it!  I knew there had to be something like that.  Thanks!
(9,447 Views)
There's even a much easier way:
under  'Options' > 'Global preferences', select the 'General' TAB, and in the 'wiring' part:
unselect the 'delete associated wires when deleting component' box
best regards
less stressed user...
(9,383 Views)
Thanks for the tip, Johan. Even I learn something new about Multisim and Ultiboard everyday.
Yi
Software Developer
(9,376 Views)
