Multisim and Ultiboard
microsoft.net framework 4.0
The installer fails to recconnaise .net framework 4.0 already installed on my computer and refuses to install. Is there a way to correct this without trying to install it again.
thanks for any help.
Message 1 of 8
(5,320 Views)
Hi Magnus,
Can you do a screen shot with the error message from the Circuit Design Suite installation, I will investigate this issue.
Tien P.
Message 2 of 8
(5,318 Views)
Here is the screenshot.
Message 3 of 8
(5,309 Views)
Hi Mahnus,
Can you have a look at this knowledge base and see if it applies to you:
http://digital.ni.com/public.nsf/allkb/C40B52827188BF4086257A370055BD82
Tien P.
Message 4 of 8
(5,294 Views)
No, I rebooted after intallation and I have also shutdown and restarted a few times since then.
Message 5 of 8
(5,288 Views)
Can you tell me where you downloaded the .net framwork 4.0, let me try it on a fresh machine and test this out.
When I looked at my registry this is what I see under:
HKey_Local Machine\Software\Microsoft
Tien P.
Message 6 of 8
(5,284 Views)
I downloaded it with windows update. This is a new computer, I just got it. I am running windows 7 home premium.
In the registry it shows that I have the same version number as you. It looks the same.
Let me know if you need any more information.
Message 7 of 8
(5,278 Views)
Hi Tien,
Any luck resolving this issue, or any suggestions?
Thanks.
Message 8 of 8
(5,224 Views)
