This widget could not be displayed.
Multisim and Ultiboard
microsoft.net framework 4.0
The installer fails to recconnaise .net framework 4.0 already installed on my computer and refuses to install. Is there a way to correct this without trying to install it again.
thanks for any help.
Message 1 of 8
(5,333 Views)
Hi Magnus,
Can you do a screen shot with the error message from the Circuit Design Suite installation, I will investigate this issue.
Tien P.
Message 2 of 8
(5,331 Views)
Here is the screenshot.
Message 3 of 8
(5,322 Views)
Hi Mahnus,
Can you have a look at this knowledge base and see if it applies to you:
http://digital.ni.com/public.nsf/allkb/C40B52827188BF4086257A370055BD82
Tien P.
Message 4 of 8
(5,307 Views)
No, I rebooted after intallation and I have also shutdown and restarted a few times since then.
Message 5 of 8
(5,301 Views)
Can you tell me where you downloaded the .net framwork 4.0, let me try it on a fresh machine and test this out.
When I looked at my registry this is what I see under:
HKey_Local Machine\Software\Microsoft
Tien P.
Message 6 of 8
(5,297 Views)
I downloaded it with windows update. This is a new computer, I just got it. I am running windows 7 home premium.
In the registry it shows that I have the same version number as you. It looks the same.
Let me know if you need any more information.
Message 7 of 8
(5,291 Views)
Hi Tien,
Any luck resolving this issue, or any suggestions?
Thanks.
Message 8 of 8
(5,237 Views)
