10-22-2012 12:25 PM
The installer fails to recconnaise .net framework 4.0 already installed on my computer and refuses to install. Is there a way to correct this without trying to install it again.
thanks for any help.
10-22-2012 01:31 PM
Hi Magnus,
Can you do a screen shot with the error message from the Circuit Design Suite installation, I will investigate this issue.
10-22-2012 08:15 PM
Here is the screenshot.
10-23-2012 02:43 PM - edited 10-23-2012 02:44 PM
Hi Mahnus,
Can you have a look at this knowledge base and see if it applies to you:
http://digital.ni.com/public.nsf/allkb/C40B52827188BF4086257A370055BD82
10-23-2012 03:29 PM
No, I rebooted after intallation and I have also shutdown and restarted a few times since then.
10-23-2012 03:51 PM - edited 10-23-2012 03:53 PM
Can you tell me where you downloaded the .net framwork 4.0, let me try it on a fresh machine and test this out.
When I looked at my registry this is what I see under:
HKey_Local Machine\Software\Microsoft
10-23-2012 04:37 PM
I downloaded it with windows update. This is a new computer, I just got it. I am running windows 7 home premium.
In the registry it shows that I have the same version number as you. It looks the same.
Let me know if you need any more information.
10-30-2012 11:13 PM
Hi Tien,
Any luck resolving this issue, or any suggestions?
Thanks.
