Multisim and Ultiboard
problem with PLL circuit with 3 IC (urgent!!)
I have checked all the wiring more than 100 times, I swear, and I don't find anything wrong with it! So why don't I get the results that I should get?
Please tell me in detail which wire should go to which number (eg. A1, B2, C4 etc...), as I have less than 24 hours to get this done. I have been trying this circuit for 3 weeks and I am fed up already, so I'd appreciate it if someone just tell  me literally which wire has gone wrong. I have done a VCO test with this and it seemed fine so I don't understand why the VCO_out is not working well. I have tried many ranges of frequency and the result is the same. OK, here I will show you the circuit I have done:
I took it from 3 different angles so you guys can see clearer, remember to zoom in!
HERE IS THE DIAGRAM, THE INSTRUCTION:
THIS IS WHAT I GET AS RESULTS:
I have also tried with lower frequency but the blue wave results were all the same as above!
In the instruction, it says that I should be getting "FREQUENCY FROM ELVIS x (N+1)" as a result, even if the wave is not completely locked.
SOMEONE HELP!!!! My friend got the right result but I don't see any difference between her circuit and mine. Can someone check? This is her circuit:
(6,207 Views)
Please do not start additional threads on the same topic. It irritates people and makes it less likely that you will get prompt help. Please keep the  discussion in  that thread.
Lynn
(6,148 Views)
