NI產品與技術 討論區
取消
顯示結果
搜尋替代
您的意思是:
Read file and 3-D plot
first of all, I am using Labview version 8.5...and Ive only used labview for a couple weeks...had no training, pretty much just self learned so Im still new to labview..if I
can get help from somebody here~ I would be really appreciate that~
and here are my problems:
1. is there anyway to import data file from excel or txt files and read from  ''Mathscript''  directly ?!
 (that I had to copy and rearrange the data file and copy paste in mathscript structure...and there should be an easier way to do that)
2. Im trying to plot all the point in 3D plot and gives the blade shape graph...
3. And a numeric control window...so I can input the offset ...for instance..input z=1.5 then the program will pull out the cross-section point between the blade and the
    z=1.5 plane
thanks for all the help~
0 積分
1 條訊息(共 2 條)
4,570 檢視
建議全華圖書或高立圖書 labview 8x,請到圖書網站查詢。
labview>>help>>find examples>>search>>mathscript>>MathScript Fundamentals.vi
labview>>help>>find examples>>search>>text>>Read from Text File.vi
如果您是新手,請先看熟以上圖書。
或來 NI Taiwan 上免費半天課程
或您是學生,7/24~25-兩天6000課程,
或透過 search 尋找關鍵字,如上,可以找到範例。
http://digital.ni.com/worldwide/taiwan.nsf/web/all/70BA49C9F31106DE482574D600200929
Message Edited by Fatty on 06-30-2009 10:08 PM
0 積分
2 條訊息(共 2 條)
4,554 檢視
