NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
怎么知道一台有GPIB接口的仪器是否支持SCPI?
如题,当然可以通过发送SCPI命令看有没有相应来判断。还有没有其他的方法?
0 项奖励
1 条消息(共 2 条)
3,002 次查看
Emm...
It is a so board question.
I think firstly you should judge whether it is a instrument belong to IEEE 488.(does it get common command set just as *IDN?,*STB?,*CLS and so on? does it get STATus and SYSTem system in SCPI standard?)
If it is a IEEE 488 instrument, I think you can control it by SCPI.
0 项奖励
2 条消息(共 2 条)
2,987 次查看
