11-05-2020 07:46 AM
Hi everyone,
I tried to install 2020 Ni Linux drivers on this page : https://www.ni.com/fr-fr/support/downloads/drivers/download.ni-linux-device-drivers.html#350003
I have a distribution based on Ubuntu 20.04 LTS.
I installed the ni-software-2020-bionic_20.1.0.49152-0+f0_all.deb package and launch the
"sudo apt update" command. I got the following error :
Err :7 https://download.ni.com/ni-linux-desktop/2020.07/deb/ni/bionic bionic Release
Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown. Could not handshake: Error in the certificate verification. [IP : 104.16.190.245 443]
Do you have problems with your certificates ?
Antoine
Solved! Go to Solution.
11-05-2020 02:45 PM
Hi Antoine,
There was a small issue with the certificate, but it should be fixed now. Could you try running apt update again?
Thank you for making us aware of the issue!
Chris
11-06-2020 03:37 AM
Thank you Chris,
Everything seems to work now.
Antoine
11-09-2020 08:22 AM - edited 11-09-2020 08:23 AM
I also had this issue which has been resolved now.
I've installed the nidaq-mx on a Ubuntu 18.04, using instruction below here:
However, when I plug in my device it is not being recognized.
Is there any solution to this?
I'm working with USB-4432 for microphone data acquisition.
Best,
Meron
01-13-2021 05:08 PM
I'm having trouble getting my LabVIEW 2020 install to recognize the DAQmx install. I've installed on openSUSE 15.1, using the Linux instructions:
But I'm also curious how you use the ubuntu version of these drivers... if ubuntu is not supported yet in LabVIEW. I'm dual booting ubuntu/openSUSE for this express reason.
Greg
